Текущее время: 03 июн 2026, 23:39
 Заголовок сообщения: Кодер MPEG4 для работы в МХ5
Сообщение Добавлено: 12 авг 2011, 23:22
Мои поздравления Всем телеортанизациям нашедшим своё место в цифровом эфире. Если бюджет отраничивает Вас в выборе дорогого кодера можете посмотреть этот прибор. Вот его характеристики:
Description:
DV-71 new generation of MPEG-4/H.264 SD/HD encoder. It supports HDMI, SD/HD SDI, YPbPr, CVBS, SPDIF input and ASI and IP output. It presents major improvements in picture quality, offering crisp and vibrant video at extremely low bit-rates. DV-71 helps deliver more SD/HD video and audio channels in the available bandwidth, enabling the launch of additional HD services in an existing digital video or a IPTV network.
Features:
● Compliant with H.264/MPEG4-AVC standard
● MPEG-1 Layer II audio encoding
● SD video input format: NTSC/PAL
● HD video input format:SMPTE-296/SMPTE-274
● HDMI, SD/HD SDI, YPbPr, CVBS input
● Digital SPDIF audio input (Optional)
● Support Dolby AC-3 audio encoding (Optional)
● Support multiplexing of MPEG4 video and audio compressing data stream, supporting DVB packing
● SI related table editing
● Support SD or HD TS stream output selection
● Two identical ASI outputs
● IP output compliant with UDP/RTP protocol (optional)
Video input and compression
Video Input – SD/HD-SDI,HDMI,YPbPr,CVBS
Video Compression - H.264/AVC 4:2:0 MP@Level 3.0 for SD, H.264/AVC 4:2:0 HP@Level 4.0 for HD
Video Encoding Bit-Rate:
● 1.5-10Mb/s for 720 x 576 x 50i, 720 x 480 x 60i,
● 4-20Mb/s for 1280x720x60p/59.94p/50p
● 5-20Mb/s for 1440x1080x60i/59.94i/50i,
● 6-20Mb/s for 1920x1080x60i/59.94i/50i
GOP structure: IBBP, IBP
Aspect ratio: 4:3,16:9
Entropy encoding: CABAC
Filter: Block eliminating filter
Advanced pre-processing: noise reduction, sharpening
Support PCR insertion, PCR sending interval ≤ 40ms
Support PSI/SI table extraction and edition
Audio input and compression
Audio Input - unbalanced audio, SD/HD-SDI embedded, HDMI
Audio Compression - MPEG1 Layer II audio encoding
Sampling rate - 48KHz
Sampling Accuracy: 24-bit
Compression rate - 32Kbps-256Kbps
Channel supporting – mono, stereo
2 stereo channels Dolby Digital® (AC-3) 2.0 encoding (Option)
Dolby Digital® (AC-3)5.1 channel encoding (Option)
ASI output
Connector - BNC connector, 75Ω
Data mode - Byte mode
Packet length - 188 Bytes
Signal level - 800mV
Output Bit rate – 1.5Mbps~72Mbps adjustable
TS over IP output
IP output - RJ45, 10/100Mbps
Error correction Pro-MPEG-FEC (Option)
Maximum output bit rate - 70Mbit/s
Protocol - UDP/RTP. Supports Multicast and Unicast
Multicast control protocol - IGMPV2
Rear panel
Analog AV connector - RCA Port for YPbPr; for all Audio;CVBS
SD/HD-SDI connector - 1×BNC, female
HDMI connector - 1×HDMI
ASI - 2×output(duplicated)
ENTHERNET - RJ45, 10/100Mbps for network management and software upgrading
TS/IP - RJ45, 10/100Mbps
Operation Environment
Operating Temperature - 0~40C
Humidity - < 85%
Power supply - AC90~260V 50Hz/60Hz 30W
Dimensions - 44mm×484mm×570mm
Net weight - 5Kg
Безусловная гарантия работоспособности ПЯТЬ лет. Послегарантийное обслуживание по договору обслуживания. Все вопросы в ЛС.
 Заголовок сообщения: Re: Кодер MPEG4 для работы в МХ5
Сообщение Добавлено: 12 авг 2011, 23:27
сковородкой по яйцам?
оригинально :mrgreen:
Сообщение Добавлено: 12 авг 2011, 23:30
и даже в долю не взял ..
наглость :mrgreen: :mrgreen: :mrgreen:
Сообщение Добавлено: 12 авг 2011, 23:32
У меня сегодня чуть мобилка от звонков из за этого ящика не расплавилась. Пусть хоть с характеристиками железа познакомятся ибо проводить полные лекции всем желающим разобраться... просто не возможно. Попробуйте и меня понять.
Саша, Я такого не говорил! Заметь это пожалуйста :wink:
Сообщение Добавлено: 13 авг 2011, 00:35
а я бы проценты брал.
с каждой сделки.
за предоставление рекламной площадки.
Сообщение Добавлено: 13 авг 2011, 08:26
Очень расстроился от этой фразы. Это они на неспециалистов ориентируются?
И странно, что AAC отсутствует. Ведь могли бы и про кристально чистый звук в AAC написать, при битрейте 8 килобит/сек. Тянуть за уши MP2 и AC3 - странно.
Сообщение Добавлено: 13 авг 2011, 08:51
Это особенности перевода с китайского на английский. Возможно такая версия перевода с китайского на русский:
Благодаря значительным улучшениям качества картинки, кодер обеспечивает чёткость и контрастность видео при достаточно низких бит-рейтах. будет более приемлема...
AAC присутствует, но лицензия специально деактивированна для снижения цены. Активировать её можно мгновенно при возникновении потребности.
 Заголовок сообщения: !
Сообщение Добавлено: 07 авг 2012, 17:48
Железо прибыло.
Кому интересно в ЛС.
Сообщение Добавлено: 26 июл 2013, 20:14
хотілось б дізнатись ціну на девайс.
Сообщение Добавлено: 30 июл 2013, 14:43
хотілось б дізнатись ціну на девайс. (відправив вже декілька повідомлень, а відповіді немає)
Сообщение Добавлено: 31 июл 2013, 12:50
Відповідь в ЛС.
Сообщение Добавлено: 03 авг 2013, 07:43
где можно купить мпег2 кодер с выходом ір? Возможно у кого освободился после перехода на мпег4?
Сообщение Добавлено: 03 авг 2013, 16:15
Есть новые. Вам нужен выход UDP или RTP? Стереопар 1 или 2? Вход SDI? Бюджет?
Ответ можно в ЛС.
Сообщение Добавлено: 06 авг 2013, 13:10
ответил в личку
